I
Irfan
Hi Derek, I earlier deployed REST Service, but now I also deployed a WebHandler to see if I get into any problem, but it seems to be working fine. Will try to figure out other possible ways to debug this problem. proenv>deploysvc.bat -v -g %WRKDIR%/TestService.zip -a 117Proj deploysvc verbose: deploying service artifact C:\OpenEdge\WRK/TestService.zip trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\commonPageFooter.html trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\commonPageHeader.html trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\commonStyle.css trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\home.html trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\home.jsp trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\index.jsp trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\ServerStatus.html trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\static\serverstatus.js verbose: found REST service TestService.paar trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\adapters\rest\TestService\TestService.paar trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\openedge\ReadMe.txt trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\openedge\SampleProj.r trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\tlr\Merge.template trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\tlr\oeabl_tlr verbose: found WEB service SampleProj.handlers trace: file unzip : C:\OpenEdge\WRK\oepas1\webapps\117Proj\WEB-INF\tlr\SampleProj.handlers trace: done verbose: adding paar files to web.xml verbose: TestService.paar already added verbose: reading handler list for web application 117Proj trace: application - oepas1 trace: webApp - 117Proj verbose: reading current handler mappings trace: looking for handler1 trace: Copying C:\OpenEdge\WRK\oepas1/conf/openedge.properties to C:\OpenEdge\WRK\oepas1/conf/openedge.tmp verbose: processing handlers for SampleProj service verbose: handler class is SampleProj verbose: adding mapping for /testURI trace: property - +oepas1.117Proj.WEB.handler1=SampleProj:/testURI trace: Moving (1) C:\OpenEdge\WRK\oepas1/conf/openedge.tmp to C:\OpenEdge\WRK\oepas1/conf/openedge.properties execution complete
