[progress Communities] [progress Openedge Abl] Forum Post: Re: Decimal Separator?
  • Thread starter Thread starter Manooj Murali
Manooj Murali
Hi - The localization settings is the only place where you can set the numeric format for a numeric (integer / decimal) field in Rollbase. We are currently offering all popular English/European numeric formats. If you would like the numeric formats to be only applicable for decimal but not for integer fields then you can still just uncheck the checkbox that says 'Enable Grouping' on the integer field. This will turn off any formatting for the integer field and the selected numeric formatting shall be only applicable for decimal and other integer fields that have "Enable Grouping" checked. Regards.
