[progress Communities] [progress Openedge Abl] Forum Post: Re: Ddc On Premise Connector
  • Thread starter Thread starter Mark Biamonte
Mark Biamonte
This is a bug in the On-Premise Connector installer. The problem is that the CATALINA_HOME environment variable is set on the system the connector is being installed on. The installer is recognizing that CATALINA_HOME is set and is using the value set for that variable as the base directory for the connector unfortunately this is not the correct directory for the On-Premise Connector. We are thinking that another product that was installed on this system set the CATALINA_HOME environment variable. We are working on fixing the installer. In the mean time to work around this problem try the following. 1) Examine and save the current value of the CATALINA_HOME environment variable somewhere 2) Delete the CATALINA_HOME environment variable. 3) Uninstall the current install of the On-Premise connector. 4) Restart the system to insure the On-Premise connector was completely uninstalled 5) Re-install the On-Premise connector 6) Set the CATALINA_HOME environment variable back to its original value. We thinking it may have been one of our other products that may have been installed on that system and set the CATALINA_HOME environment variable. Is Progress OpenEdge or Progress Rollbase installed on that system? Regards Mark
