[progress Communities] [progress Openedge Abl] Forum Post: Re: Database Triggers Not Fired...
  • Thread starter Thread starter Mike Fechner
Mike Fechner
Are you sure that the trigger is not firing? The alternative reason might be that the BUFFER-COPY happening during the SAVE-ROW-CHANGES (after the CREATE done by the SAVE-ROW-CHANGES) overwrites the value. You should use the skip fields parameter on the SAVE-ROW-CHANGES to protect your PUK field from getting overwritten. We have no problem with create triggers and prodatasets that way. Von: gdb390 [mailto:bounce-gdb390@community.progress.com] Gesendet: Dienstag, 6. September 2016 12:30 An: TU.OE.Development@community.progress.com Betreff: [Technical Users - OE Development] Database triggers not fired when creating a record in business entity Update from Progress Community gdb390 Hi, OpenEdge 11.6 I have created a database table with a create & write trigger. In the create trigger the PK (which is an ID) is filled with a number from a sequence . I created a business entity eg Customer.cls based on the table. You get a temp-table with the before-table and some methods to handle data access. One of them is the create method. If I create a temp-table record (tracking-changes = true) and pass it to the create method, the record is created in the database, but the trigger is not fired. Why is that ? Am I missing something ? View online You received this notification because you subscribed to the forum. To stop receiving updates from only this thread, go here . Flag this post as spam/abuse.
