[progress Communities] [progress Openedge Abl] Forum Post: Re: Current-value() Statement...
  • Thread starter Thread starter George Potemkin
George Potemkin
> In V11.6 the same statement additionally uses the TXQ latch (twice). And it gives us an opportunity to test a contribution of TXQ latch to the performance. Due the TXQ latch each call of the current-value() function creates 7 latch locks in V11.6 compared to 5 latch locks in V10.2B - 40% (=2/5) more latch locks. Comparing the results of the sequence readprobe tests: V11.6 vs V10.2B Users Increase of SEQ reads/sec 1 - 22.6% 11 - 38.1% 50 - 20.6% 11 users is the user count that provided the best result in the tests, IOW, when the most busy latch is almost 100% busy. In this case the change in performance closely matches the change of the latch locks. Just for a record: the tests were run with the -spin 10,000 -lruskips 100. The current-value() function also locks the LRU latch (though the sequence block is not on LRU chain). LRU is just 1 of 7 (~14%) latch locks requested by the function in V11.6. We can cut these locks by the -lruskips times. 11.6 lruskips: 0 vs 100 Users Increase of SEQ reads/sec 1 - 5.3% 11 - 6.9% 50 - 7.8% Eliminating the LRU latch locks does increase the performance but the LRU is obviously is not the most busy latch in the sequence readprobe tests. Also the SEQ reads for the best user count turned out to be 7-8 times higher than the reads generated when only one session was running. This number seems to be related mainly to the number of latches used during the tests. 11.6.1 spin.10000.skips.0 Users: 1, SEQ reads: 55,053 Users: 12, SEQ reads: 388,358, Increase by 7x, Latch timeouts: 7 Users: 50, SEQ reads: 365,103, Decrease by 6%, Latch timeouts: 837 11.6.1 spin.10000.skips.100 Users: 1, SEQ reads: 57,993 Users: 11, SEQ reads: 415,406, Increase by 7x, Latch timeouts: 0 Users: 50, SEQ reads: 393,656, Decrease by 6%, Latch timeouts: 745 10.2B08 spin.10000.skips.100 Users: 1, SEQ reads: 71,112 Users: 10, SEQ reads: 573,848, Increase by 8x, Latch timeouts: 0 Users: 50, SEQ reads: 474,686, Decrease by 21%, Latch timeouts: 803 All numbers are per second. One more observation: Next after the best user count seems to always course a lot of the naps for the most busy latch (a jump from 0 to 200-300 naps per sec). Probably it's because the -spin 10,000 is not the best value for those latches. Conclusion: The latches are real! We can feel them! ;-)
