L
Libor Laubacher
OEM can monitor other OE/OEM instances remotely. That remote instance is sometimes called 'Container'. Tho I am not sure how it would apply in your case. Instead of fiddling with schedules, you can also, before the maintenance disable the resources you don't want to be alerted on, and then once maintenance completes, and they have been started, you can enable them again. The command to look at is "fathom". Check "fathom -disable -help" and "fathom -enable -help" for more info.
