[progress Communities] [progress Openedge Abl] Forum Post: Re: Connectivity From Obiee 11g...
  • Thread starter Thread starter Brian Derwart
B
Brian Derwart
This driver requires a JVM. Please also verify that you have the path to a libjvm.so on your shared library path in addition to the path to the driver libraries. Also, some of the properties you listed in the data source(like ServerMachine) are not valid for the Progress MongoDB ODBC driver. There is a sample odbc.ini that gets installed with the product. Please switch to modifying and using(via the ODBCINI env variable) that file. This Quick Start Guide should help: documentation.progress.com/.../mongoodbc_unix_quickstart.htm Please verify that you can load the driver outside the OBIEE environment and then work on configuring OBIEE for connectivity. Please keep us posted on your status.
