Dileep Dasa
There is no problem with the Eclipse setup. The error you are seeing is due to a database server configuration. You ran out of server slots that were configured for the database to use. So, you need to reconfigure the database server. You have to properly assign values for certain database startup parameters like -Mn -Ma -Mi etc. You can find much detailed information about configuration here: knowledgebase.progress.com/.../How-to-set-up-a-secondary-login-broker-for-SQL-92-connections-for-Progress-OpenEdge-database
