Andriy Mishin
Thank you Matt! I added this, but no effect for "result" field. In addition, I found that there is no effect only for integer. I added a new field with the character type (res2). DEFINE QUERY q1 FOR combo1 SCROLLING. DEFINE BROWSE b1 QUERY q1 NO-LOCK DISPLAY combo1.exec_date COLUMN-LABEL "Import!Data" combo1.result VIEW-AS COMBO-BOX LIST-ITEM-PAIRS "Performed",-1,"Part. performed",0,"Not performed",1,"Uploded",2 combo1.res2 VIEW-AS COMBO-BOX LIST-ITEM-PAIRS "Performed",-1,"Part. performed",0,"Not performed",1,"Uploded",2 WITH SIZE 40 BY 10 SEPARATORS MULTIPLE. DEFINE FRAME f1 b1. OPEN QUERY q1 FOR EACH combo1. ENABLE b1 WITH FRAME f1. APPLY "VALUE-CHANGED" TO BROWSE b1. WAIT-FOR WINDOW-CLOSE OF CURRENT-WINDOW. For character field that's work fine Why it does not work for the integer field - this expected behavior? or a bug?
