Ruben Dröge
If your auto-number field is an integer field you could also do something like this I guess, otherwise, you'd need to cut out the integer part, add +1 and then add the characters to it again: var v_newarr = []; var arr = rbv_api.selectQuery( "select AutoNumber from Order ORDER by AutoNumber DESC", 1); var numberpart = arr[0]; var number = numberpart[0]; v_newarr['Description'] = 'Clone Order'; v_newarr['AutoNumber'] = number + 1; createNewRecord(v_newarr); function createNewRecord(recarr) { rbv_api.cloneRecord("Order", {!id}, v_newarr); } This apart from the fact that I think the clone api should be aware of auto-numbering....
