[progress Communities] [progress Openedge Abl] Forum Post: Re: Changes Made In Rollbase...
  • Thread starter Thread starter Shivani Silveri
Shivani Silveri
Hi John, Could you check if there is any error on the Log file? You will be finding that at Object Definition -> Log. Ideally an Update request should be called to make the modifications at the DB. Also, which version of Rollbase are you using? Thanks, Shivani.
