C
cSocaciu
I think you must use the external DLL libraries under windows to achieve this: PROCEDURE PageSetupDlgA EXTERNAL "comdlg32.dll":U: DEFINE RETURN PARAMETER answer AS SHORT. DEFINE INPUT-OUTPUT PARAMETER tagPSD AS MEMPTR. END PROCEDURE. PROCEDURE PageSetupDlgW EXTERNAL "comdlg32.dll":U: DEFINE RETURN PARAMETER answer AS SHORT. DEFINE INPUT-OUTPUT PARAMETER tagPSD AS MEMPTR. END PROCEDURE.
