[progress Communities] [progress Openedge Abl] Forum Post: Re: Binary Dump And Load, Apply...
  • Thread starter Thread starter Dmitri Levin
Dmitri Levin
I have been using Bravepoint's Pro D&L several times since 2005. You will have some small down time, that will be basically the time to restore a database back in place. Definitely not 25 hours. The actual D&L I would be doing on a replica (server B) and then bring the resulted database to server A. And then apply the changes that were made during that time (not through apply AI) while the old primary still working. The best thing that I like about Bravepoint's Pro D&L is that you are not in a hurry in D&L process. It takes as long as it takes. If something goes wrong you just try again and the downtime that I talked above happens only when everything is done, well almost everything.
