[progress Communities] [progress Openedge Abl] Forum Post: Re: Best Way To Compress...
  • Thread starter Thread starter Mark Bartscherer
Mark Bartscherer
If you use the WRITE-XML() Method you can use a MEMPTR as target-type. To encode just use the base64-encode function passing the memptr. You will get a longchar with base64 encoded text Is this what you are looking for?
