[progress Communities] [progress Openedge Abl] Forum Post: Re: Ai Best Practice (v10.2b07)
  • Thread starter Thread starter Betty Hardin
B
Betty Hardin
Sounds like I should be ready to go. Double checking myself. Will stick with variable extents; they've worked fine for all these years! Thanks so much for the tip on using TWO directories; in the past I had my batch file abort the swtich and send me an alert that my archive directory was not available. Very familiar with FORFILES .. use it quite frequently in fact. Will look into 10.2b08. Thank you!
