Matt Gilarde
Create the menu before the browse widget is displayed and set the browse widget's POPUP-MENU attribute to the menu's handle. Then when you right click on the browse the menu will be automatically displayed (you don't need the RIGHT-MOUSE-DOWN trigger). You can create a browse and popup menu in AppBuilder to see the code that is generated.
