[progress Communities] [progress Openedge Abl] Forum Post: Re: Abl Unit Test 11.6 -...
  • Thread starter Thread starter Phani Sajja
P
Phani Sajja
By default, it will be created in working directory. If you want to change, you change the working directory from 'Run Configurations' -> 'Working directory' in the ABLUnit main page. It always overwrite this file if you run a different test entity in the next run. You can use the Export feature from ABLUnit results view rather than relying on this results.xml file. -- Regards, Phani S.
