W
whenshaw
It is surprising that the GET request for home.html already includes a JSESSIONID -- did you successfully access the Web application from the same browser session before you ran the test? Another question -- are you using OpenEdge 11.6.0, the FCS? There is a bug in it that causes an error when you try to access an OE Web application using CORS, if the application uses Form authentication. The symptoms are not exactly what you are seeing, but if you are using 11.6.0 and can upgrade to 11.6.1, that might be worth a try.
