Mayank Kumar
Hi Iram, Thanks for confirming. As per the current behavior, related fields are read only in grid control. There was an issue identified in 4.5.x related to this, where the related field were in Edit mode but not rendering in grid control. Ideally, they should be read only. We fixed this issue in 5.0 and now the related fields are read only in grid control. Could you please try it by marking the related fields as read only from the grid control configuration and see if that works for you. Regards, Mayank
