[progress Communities] [progress Openedge Abl] Forum Post: Re: 4.0.4 - Related Field In A...
  • Thread starter Thread starter Meryk
Meryk
Hi Mani, Thanks for the reply. So Steps 1-2-3-4 are correct. Now you will need to go to a object B record view page, then click attach button in the Object A related Section. In that selector page that opens, add your 'RelatedFieldC1' in the detailed search. You should be able to see the issue with this now. Thanks, Meryem
