[progress Communities] [progress Openedge Abl] Forum Post: Re: [4.0.4.0] - Related Field...
  • Thread starter Thread starter Vimalkumar Selvaraj
V
Vimalkumar Selvaraj
Hi Iram, Can you confirm whether Grid rendered or not?. You see issue when data loaded into Grid?. If yes is it possible to get current view data from kendo DataSource and see if there is any empty or null values from browser console. kendoGrid.dataSource.view() -- > Will give you all records on current page. You should use our client SDK to get kendoGrid. You can easily port our Rollbase applications to other environment. Use seed records option to attach records and port your applications to EAP and test it. Other option is you can create sample app with only few objects and try to replicate same issue in another App and try to share with us app.xml to debug this issue further. Thanks, Vimal.
