[progress Communities] [progress Openedge Abl] Forum Post: Re: [4.0.4.0] - How To Debug A...
  • Thread starter Thread starter Rajkumar Mateti
Rajkumar Mateti
HI Iramk, I have tried the scenario you mentioned it seems to be working fine. Can you verify the steps i followed or same as you did. And let me know if i miss anything. 1) Create 3 objects A,B and C with Contact property enabled. 2) Created relationship as follows One A to Many B and Many B to One C 3) Created an Email template in A object and Send email trigger and used the token from drop down (Bs:Cs: Email Address) which is {!R8414.R8554.email}. Email trigger is configured with After create timing. 4) Created a record in C with valid value in Email field 5) Created a record in B and selected the record created in C for C lookup in B object create page 6) Now created a record in object A and selected the record created in B for B lookup in A create page. Observed that got the email to the value given in C object email address. Thanks, Rajkumar
