[progress Communities] [progress Openedge Abl] Forum Post: Re: [4.0.4.0] - Conditional...
  • Thread starter Thread starter Sri Harsha
Sri Harsha
Hi, Conditional Formulas are executed only on a page load and accordingly the "edit"/"delete" functionality is disabled as per the return value of the formula. Dynamic hiding of edit/delete actions is not possible. You may have to write server-side validation (using the created-at/updated-at field values) if you need to achive this. Or may be a trigger of type "Validate Record Data" by checking if the updated-at value is more than 10 minutes later of the main record. Hope this helps. Regards, Harsha.
