[Progress Communities] [Progress OpenEdge ABL] Forum Post: Pool range - difference in behavior between 11.3 and 11.7
  • Thread starter Thread starter hinko65
H
hinko65
Hello, We migrated recently from 11.3 to 11.7 and hav =e for bot the OE Workgroup RDBMS license. For the webspeed we use a pool range of 6 agents (initial start, minimum and maximun) For the appserver we use a pool range of 3 agents ( initial start, minimum and maximun ). In the Openedge explorer in 11.3 you see the 6 agents at the webspeed broker and the 3 agents at the appserver broker. In the Openedge explorer in 11.7 howver you see the 2 agents at the webspeed broker and the 2 agents at the appserver broker. I looked at the logfiles from webspeed, appserver, database, nameserver and adminserver. No error messages indicating that something is wrong. It also looks right for the number of users/connection permitted(-n parameter). In another environment we have a 11.7 Enterprise licence. There it works fine. Is there a reason known why in a OE Workgroup RDMS environment only two (2) agents are starting, despite the pool range? Kindly regards, Hinko
