[Progress Communities] [Progress OpenEdge ABL] Forum Post: PASOE 12.2 APSV Issues
  • Thread starter Thread starter Darren Parr
Darren Parr
Hi After upgrading, it seems I have a big issue getting this to work. Our system uses state-reset connections in classic appserver. This has always worked great with PASOE. We have code which bends the connection in the connect procedure and unbounds in the disconnect procedure as well as quits. Since upgrading to 12.2 this application does not run. Moreover it crashes PASOE so no other connections are possible. As part of the login procedure, we use the connect procedure to return a list of resources as a custom error message which our client reads and utilises. This is how we implement our two stage login procedure. Unfortunately throwing an apperror is mostly lost to the client and the client throws an error of its own. This has worked in 12.0 and 12.1 but does not work in 12.2. Any ideas? Otherwise its back to 12.1. This is not usable at the moment. Regards Darren
