[Progress Communities] [Progress OpenEdge ABL] Forum Post: PAS - Pick up new r-code
I've been using PAS for some time and have often made use of the "resource timeout" to kill my _mproapsv.exe after a specified number of seconds so that it will pick up new r-code. In prior posts (by Irfan and David Cleary?) I had heard some hints of a feature whereby the jconsole (via JMX) would allow us to manage PAS agents and clear out the cached r-code. However, I'm not finding anything that appears to be a direct match for that feature. Below is the list of API methods. As best I can tell, the only way to clear out the cached r-code is to run stopAgent on it. Is that the recommended approach?
