F
fiservarvind
Hi, DB is created by scripts/installs and it copied into the users C directory. On that db I enabled TDE with Manual mode. When I try to run that db using prowin32.exe it successfully able to connect without asking for -Passpharse. On the other hand if I try to run it using proserve commend it is asking me for -Passpharse. Also If I create db using DataDictinary or prodb those are working fine and asking -Passphrase for manual encryption. I am not sure if TDE has limitations based on how we have created DB? On QA\PROD environments we use prowin32.exe to run db and application. I am not sure what we are missing here. Can someone please suggest on this?
