[progress Communities] [progress Openedge Abl] Forum Post: Isauthorized() With 2...
  • Thread starter Thread starter kh-it
K
kh-it
Dear, We have a problem with our page refresh the isAuthorized() return yes when another JSDOSession(UnAuthenticated) is loaded. Even if the JSDOSession is the FORM and not the ANON JSDOSession. Vars: authUnAuthenticated = new progress.data.AuthenticationProvider({ authenticationModel: progress.data.Session.AUTH_TYPE_ANON, uri: ServiceURI }); auth = new progress.data.AuthenticationProvider({ authenticationModel: progress.data.Session.AUTH_TYPE_FORM, uri: ServiceURI }); Login: auth.login(pUser, pPassword).done(function(session, result, info) { session = new progress.data.JSDOSession({ serviceURI: ServiceURI, authenticationModel: progress.data.Session.AUTH_TYPE_FORM, name: " A pplicationName ", authProvider: auth }); Check at page refresh: JSDOSession = new progress.data.JSDOSession({ serviceURI: ServiceURI, authenticationModel: progress.data.Session.AUTH_TYPE_FORM, name: " ApplicationName ", //pApplicationName authProvider: auth }); return JSDOSession; Load UnAuthenticated: progress.data.getSession({ serviceURI: ServiceURI, catalogURI: PreCatalogURI + "UnAuthenticatedService.json", authenticationModel: progress.data.Session.AUTH_TYPE_ANON, name: " ApplicationName UnAuthenticated ", authProvider: authUnAuthenticated }) isAuthorized: If page refresh occurs I do : JSDOSession.isAuthorized() .done(function(session, result, info) { If I check the properties it's really from the FORM and not ANON but it return that it's authenticated. Why? Is this a problem because I'm using the same ServiceURI. I thought it should check the 2 JSDOSessions separately. Or do I have to extend the jsdo library for this. I'm searching for a while after this problem without success. I hope somebody can help. Progress version: 11.7.1 JSDO: 4.4 Thank you in advance KH-IT
