[Progress Communities] [Progress OpenEdge ABL] Forum Post: Is there a way to EXPORT dates and always get yyyy format?
  • Thread starter Thread starter S33
S33
When I export a record with date fields, is there a way to force dates in that record to always be in the mm/dd/yyyy (4-digit year) format? (I assume it's abbreviating when possible, based on the current -yy parameter.) Example: def temp-table tt no-undo field dt1 as date format '99/99/9999' field dt2 as date format '99/99/9999' . create tt. update tt. output to /tmp/x. export tt. output close. My input: dt1 dt2 12/31/2020 04/01/1066 Contents of output: 12/31/20 04/01/1066 The problem is that if the -yy is different when the record is later imported, I might not get what I expect. This is in 10.2b08 on RHEL.
