thierryk
Hi, I'm trying to call a service that requires an SSL authentication. A pkcs7 format is expected by the web server. Here is what i've done so far. Step 1 : I got a trusted client certificate (.p7b) and validated it against the web server. It went fine. Step 2: I converted the p7b certificate in order to register into the dlc/cert store. I tried PEM and DER. It went fine but i'm not sure what I should really generate regarding keyfiles. Step 3: I implemented the client side to do the POST request using OpenEdge.NET library. At execution I got error 9318. So it seems like the ssl checking went wrong. My environment : Openedge 11.7 No PASOE using in this case. I'm a bit confuse about what is and what is not possible regarding OpenEdge environment and certificate format so I'm looking for a little help. Thanks for your help.
