[progress Communities] [progress Openedge Abl] Forum Post: How To Return A Different...
  • Thread starter Thread starter Ruben Dröge
Ruben Dröge
At this moment it seems that whatever I do, once I approve (using the approval app) an object, it always puts my source object to status 'Approved' (or any other workflow status with integration code $APPROVED). Is there a way to influence the status coming from the Approval app? My objects workflow will have multiple approval steps and I want to be able to set my objects status to 'Approved by PM' / 'Approved by PL' according to the steps of my workflow/approval. Do I need to create multiple 'Approval status pages' and link those to my Approval actions first and then add scripting to those pages' submit actions to change the workflow status of my source object?
