[progress Communities] [progress Openedge Abl] Forum Post: How To Create Prodataset With...
  • Thread starter Thread starter Rod Anderson
Rod Anderson
I'm trying to create a PDS that the parent temp table is the only temp table that has a db relationship. All other temp tables would be used during the life of the PDS and have a after-fill field relationship built to the parent. I've been working on this for a couple days so any pointers would be appreciated. I keep getting FILL requires an attached data-source for buffer EngineInputTable, or an active before-fill callback procedure. (11874). I'm starting off simple with the first tt based on an actual table in the db. The second tt has no relationship to the db but could have an implied relationship to the first tt if that makes since.
