Sivarami Reddy Marella
Hi Fuelfire, I saw lot of posts from you related to Generic JMS with IBM MQ and these are very helpful.Thanks for that. I am new to JAVA and I want to generate the .jar file for AdminObjectFinder.cls file how can I do that? When I am running below code I am getting the error message - "Error connecting to the JMS Appserver Service", Below i have pasted sonicmq1 server log also. /*------------------------------------------------------------------------ File : Consumer.p Purpose : Syntax : Description : Author(s) : Created : Thu Jun 01 14:14:02 IST 2017 Notes : ----------------------------------------------------------------------*/ /* *************************** Definitions ************************** */ BLOCK-LEVEL ON ERROR UNDO, THROW. /* ******************** Preprocessor Definitions ******************** */ /* *************************** Main Block *************************** */ DEFINE VARIABLE ptpsession AS HANDLE. DEFINE VARIABLE consumerH AS HANDLE. debugger:initiate(). debugger:set-break(). /* Creates a session object. */ RUN jms/jmssession.p PERSISTENT SET ptpsession ("-H localhost -S 3620 -AppService AD.sonicMQ1 -DirectConnect"). /* RUN jms/jmssession.p PERSISTENT SET ptpsession ("-H localhost -S 5162"). */ RUN setBrokerURL IN ptpsession (INPUT "TestQueueManager"). /* Connect to the broker. */ RUN beginSession IN ptpsession. /* Subscribe to the Sample.Q1 queue. Messages are handled by the "messageHandler" internal procedure. */ RUN createMessageConsumer IN ptpsession (THIS-PROCEDURE, /* This proc will handle it */ "messageHandler", /* name of internal procedure */ OUTPUT consumerH). /* Do not create a new message for each received message */ RUN setReuseMessage IN consumerH. RUN receiveFromQueue IN ptpsession ("SampleQ1", /* name of queue */ ?, /* No message selector */ consumerH) NO-ERROR. /* Handles incoming messages*/ /* Start receiving messages */ RUN startReceiveMessages IN ptpsession. /* Wait forever to receive messages since "u1" is never applied. */ WAIT-FOR u1 OF THIS-PROCEDURE. PROCEDURE messageHandler: DEFINE INPUT PARAMETER messageH AS HANDLE. DEFINE INPUT PARAMETER msgConsumerH AS HANDLE. DEFINE OUTPUT PARAMETER replyH AS HANDLE. /* Creates a reply message. The reply is published automatically when control returns to the ABL–JMS implementation. */ DISPLAY DYNAMIC-FUNCTION('getText':U IN messageH) format "x(70)". RUN deleteMessage IN messageH. APPLY "U1" TO THIS-PROCEDURE. END. Error Message from sonicMQ1.server log. Main >====================================================================== Main >(Jun 2, 2017 13:33:09:562) C:\OpenEdge\WRK\sonicMQ1.server.log opened. Main >(Jun 2, 2017 13:33:09:562) : Starts Adapter server logging. Main >(Jun 2, 2017 13:33:09:562) : LoggingLevel set to = 5 Main >(Jun 2, 2017 13:33:09:563) : The system property: sonicMQExtensions is set to false Main >(Jun 2, 2017 13:33:09:563) : The classpath is set to C:\Progress\OpenEdge\java\progress.jar;C:\Program Files\IBM\WebSphere MQ\java\lib\com.ibm.mqjms.jar Main >(Jun 2, 2017 13:33:09:569) : Reading jmsProvider.properties from location : C:\Progress\OpenEdge\properties\jmsProvider.properties Main >: A public jmsfromABL.AdminObjectFinder class was not found. S-0001>(Jun 2, 2017 13:33:56:269) 10.242.244.47::sonicMQ1::3620::dc4e308cfa0ca490:3a529678:15c67d459ad:-7fec: Startup Parameters: jmsServerName: Point-To-Point brokerURL: TestQueueManager user: password: clientID: null pingInterval: transactedPublish: false transactedReceive: false singleMessageAck: false symbiontAdapter: false jmsDomain: true S-0001>(Jun 2, 2017 13:33:56:273) S-0001: receive message queue size set to 10 S-0001>(Jun 2, 2017 13:33:56:275) S-0001: browse message queue size set to 500 S-0001>(Jun 2, 2017 13:33:56:276) : In SessionContainer() S-0001>(Jun 2, 2017 13:33:56:276) : Looking up ConnectionFactory in JNDI Object Store S-0001>(Jun 2, 2017 13:33:56:276) : Connection Factory object not found in JNDI Object Store. Creating using jmsProvider.properties file S-0001>(Jun 2, 2017 13:33:56:276) : Creating JMS connection factory with Broker URL as [ TestQueueManager ] S-0001>(Jun 2, 2017 13:33:56:512) : Setting Queue Manager TestQueueManager on Connection Factory Class com.ibm.mq.jms.MQConnectionFactory S-0001>(Jun 2, 2017 13:33:56:514) 10.242.244.47::sonicMQ1::3620::dc4e308cfa0ca490:3a529678:15c67d459ad:-7fec: Using connection values: 26,null,true,,true,false,-1,-1,false,0,false,false,,10000,0,30,false,60,0,20,0,,null,null,CTSC00520904801,localhost S-0001>(Jun 2, 2017 13:33:56:637) 10.242.244.47::sonicMQ1::3620::dc4e308cfa0ca490:3a529678:15c67d459ad:-7fec com.ibm.msg.client.jms.DetailedJMSException: JMSWMQ0018: Failed to connect to queue manager 'TestQueueManager' with connection mode 'Bindings' and host name 'localhost(1414)'. Check the queue manager is started and if running in client mode, check there is a listener running. Please see the linked exception for more information. at com.ibm.msg.client.wmq.common.internal.Reason.reasonToException(Reason.java:595) at com.ibm.msg.client.wmq.common.internal.Reason.createException(Reason.java:215) at com.ibm.msg.client.wmq.internal.WMQConnection. (WMQConnection.java:413) at com.ibm.msg.client.wmq.factories.WMQConnectionFactory.createV7ProviderConnection(WMQConnectionFactory.java:8475) at com.ibm.msg.client.wmq.factories.WMQConnectionFactory.createProviderConnection(WMQConnectionFactory.java:7814) at com.ibm.msg.client.jms.admin.JmsConnectionFactoryImpl._createConnection(JmsConnectionFactoryImpl.java:299) at com.ibm.msg.client.jms.admin.JmsConnectionFactoryImpl.createConnection(JmsConnectionFactoryImpl.java:236) at com.ibm.mq.jms.MQConnectionFactory.createCommonConnection(MQConnectionFactory.java:6024) at com.ibm.mq.jms.MQConnectionFactory.createConnection(MQConnectionFactory.java:6049) at com.progress.messaging.jms.SessionContainer.createConnection(SessionContainer.java:1519) at com.progress.messaging.jms.SessionContainer.init(SessionContainer.java:303) at com.progress.messaging.jms.JmsConnection. (JmsConnection.java:39) at com.progress.messaging.jms.jms._connect(jms.java:306) at com.progress.javafrom4gl.implementation.JavaServlet. (JavaServlet.java:81) at com.progress.javafrom4gl.implementation.ServiceImpl.createConnectionServlet(ServiceImpl.java:106) at com.progress.ubroker.broker.ubServerThreadIPC.write(ubServerThreadIPC.java:433) at com.progress.ubroker.broker.ubASserverThread.processConnect(ubASserverThread.java:574) at com.progress.ubroker.broker.ubServerThread.processEvent(ubServerThread.java:1210) at com.progress.ubroker.broker.ubServerThread.mainline(ubServerThread.java:479) at com.progress.ubroker.broker.ubServerThread.run(ubServerThread.java:356) Caused by: com.ibm.mq.MQException: JMSCMQ0001: WebSphere MQ call failed with compcode '2' ('MQCC_FAILED') reason '2058' ('MQRC_Q_MGR_NAME_ERROR'). at com.ibm.msg.client.wmq.common.internal.Reason.createException(Reason.java:203) Thanks, Sivarami
