[progress Communities] [progress Openedge Abl] Forum Post: Fw: Progress Alert And...
  • Thread starter Thread starter Jean Richert
Jean Richert
From: noreply@progress.com Sent: Tuesday, March 29, 2016 6:35:35 AM (UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna To: Jean Richert Subject: Progress Alert and Notification Service: Rollbase Dear Jean Richert, Below are your new Rollbase notifications. Article - ALL Publish Date Article# Solution Title 28-Mar-2016 15:03 EDT 000067666 Is there any trace when we install an App into Rollbase? 28-Mar-2016 14:22 EDT 000067665 Upgrading Rollbase with multiple database 28-Mar-2016 10:33 EDT 000067655 Relationship between External objects and Native objects 28-Mar-2016 09:52 EDT 000067643 Error: com.rb.util.db.a530: Thread already has running transaction. If you are using custom triggers please make sure you follow Rollbase guidelines. 28-Mar-2016 09:36 EDT 000067634 Error: Error loading query : In getSelectQuery() ==> m_selectQuery==null 28-Mar-2016 09:19 EDT 000067632 Error when accessing field CREATEDAT using external tables 28-Mar-2016 09:19 EDT 000067633 404 error when accessing new record page with Grid 28-Mar-2016 08:39 EDT 000067631 How to retrieve data from lookup fields when using external tables? 28-Mar-2016 07:52 EDT 000067630 Error "Database table does not exist" when updating an application using external tables 28-Mar-2016 07:37 EDT 000067628 social media integration in rollbase 28-Mar-2016 07:35 EDT 000067627 How to set a record read only after one of the field is set to a certain value? 28-Mar-2016 07:33 EDT 000067626 Is there a rollback function for deleting users? 28-Mar-2016 07:31 EDT 000067625 Hide Operator in Detailed Search selector page 28-Mar-2016 07:29 EDT 000067624 Can you add multiple database in database.xml in a trial version? 28-Mar-2016 07:27 EDT 000067623 Gmail account back button not working 28-Mar-2016 07:23 EDT 000067622 Default date value in Detailed Search Criteria Field 28-Mar-2016 07:20 EDT 000067621 Drop down lists in new UI 28-Mar-2016 07:17 EDT 000067620 Detach a record - Client side 28-Mar-2016 07:16 EDT 000067619 Quick create option for communication log 28-Mar-2016 07:14 EDT 000067618 New UI - How to set values in Reminder and Duration Fields 28-Mar-2016 07:12 EDT 000067617 New UI - Date/Time Field default value not set 28-Mar-2016 07:10 EDT 000067616 What is the limit on the number of fields per object? 28-Mar-2016 07:08 EDT 000067615 New UI: multi language field in listview not showing value in correct language configured for user 28-Mar-2016 07:05 EDT 000067614 Rollbase Portal CSS conflicts cause Kendo UI to behave strange. 28-Mar-2016 07:03 EDT 000067613 Setting field level permissions on OESO fields in Rollbase 28-Mar-2016 07:01 EDT 000067612 Search Results Page - New UI 28-Mar-2016 06:59 EDT 000067611 How to put row number in a column to the grid control copyright (C) 2014 Progress Software Corporation. All Rights Reserved. Modify or update your Subscription Service NOTICE: This message may contain an advertisement or solicitation as defined by the CAN-SPAM Act of 2003. This message was sent by Progress Software, 14 Oak Park Drive, Bedford, MA 01863 USA.
