[progress Communities] [progress Openedge Abl] Forum Post: Decimal Separator?
  • Thread starter Thread starter Wim
W
Wim
In former releases one could describe the decimal seperator on field creation. The Dutch have an oddly way of displaying the field, namely they would use a 'komma' as separator. However they work on EN keybord layouts. Meaning that the numlock-numeric keybord part will be used and even on using the 'dot' it was possible to display a 'komma' instead when the record was saved. Again that was when one could define the fields decimal separator for each field. In this version only the settings (my localisations) can be used and therefore they above function is no longer available. In what way is there a work around? Second question: in localisation only the decimal value kan be set on decimal field disolay, there is no possible setting for numeric fields, e.g. if one does not want to work with a Thousand 'dot' on those numeric fields, but one does on decimal fields there is no difference that one can make. So we would need a display format for only numeric field value's.
