[progress Communities] [progress Openedge Abl] Forum Post: Build Is Showing Successful In...
  • Thread starter Thread starter shilpi.agarwal3373
shilpi.agarwal3373
Hi team, Can you please tell me, What changes should be done in ANT script(running ABL Unit test case) to see the Build Failed. In every case, I am getting Build Successful even failure of one test case which is written in ABL Unit. ANt Script is -. output is- Buildfile: C:\shilpi\POC\ablunit\build.xml init: taskdef: prepare: [echo] Directory created clean: [echo] clean done compile: [PCTCompile] PCTCompile - Progress Code Compiler [PCTCompile] 11 file(s) compiled [echo] Build process ablunit: [ablunit] Running C:\shilpi\POC\ablunit\tests\testDelcust.p [ablunit] Tests run: 0, Success: 0, Errors: 0, Failures: 0, Time elapsed: 0.001 sec [echo] Run Test cases BUILD SUCCESSFUL Total time: 10 seconds When I run the test case(testDelcust.p) through Progress ABL Unit Application, i am finding one failure. But when I run this testcase through ANT script, Build comes out successful.. Is there need to change in ANT script? What changes should be done? Please suggest.
