Roger Blanchard
When using the -b startup parameter should an OE icon be displayed in the taskbar? This module has no UI and is used for replication. If I put my mouse over the icon you can see a grey progress window. I am using the following; prowin32.exe -b -pf guistart.pf -ininame ospreypos.ini -p StartSyncManager.r -errorstack prowin.exe -b -pf guistart.pf -ininame ospreypos.ini -p StartSyncManager.r -errorstack prowc.exe -b -pf guistart.pf -ininame ospreypos.ini -p StartSyncManager.r -errorstack If I remove the -b I do not see the icon in the taskbar. prowin32.exe -pf guistart.pf -ininame ospreypos.ini -p StartSyncManager.r -errorstack
