P
Piotr Ryszkiewicz
Hi, I have to fix some prehistoric code written using ADM1 framework. Unfortunately, I am not familiar with ADM1 nor ADM2. I was able to fix some initial problems, but now I am stuck with following: I have tabbed view (Folder). When I change value of a fill-in field in first tab, it should change value of another fill-in in second tab, and then apply "LEAVE" trigger to that field, so that other fields on that tab are also populated. I did it using PUBLISH/SUBSCRIBE, but I expect this is not standard way in ADM1. Maybe that leads to current problem: fields on second tab are filled as expected, but when I choose "OK" button, changes are not saved. Looks like it doesn't know, that the values have been changed (The standard question "Do you wish to save..." does not appear). When I type anything to any field on second tab everything is saved as expected. So the question is: how to let ADM1 know that values on the second tab have been changed ? BTW, is there any documentation regarding ADM1 available ? Regards, Piotr
