K
Kushal Basnet
Hi Guys, Well, there is this one simple script that is used to generate an Excel Report using the COM-HANDLE (ActiveX Controller). It is very simple script to generate excel report which you can find in knowledge base too. The problem is when i run the script in Procedure Editor, Excel is generated flawlessly but when i do the same through the appserver connection, Following error occurs which can be found in appserver.log file. [16/08/03@12:36:21.868+3200] P-001080 T-012364 1 AS -- (Procedure: 'Excelinit Excel-Example.p' Line:71) Error occurred while accessing component property/method: Add. Amazing thing is , when i do the same with another version of progress (Progress 11.5), it works fine !!!! Currently i am using progress 11.6 version, and MS Excel is Genuine. MS Excel 2007.
