atuldalvi123
When I execute the below code with another .p, I have this message : FILL requires an attached data-source for buffer , or an active before-fill callback procedure. (11874) Suggest modification in below Code -------- {/Temp-DB/dsOrderTT.i} {Temp-DB/dsOrder.i} DEFINE INPUT PARAMETER piOrderNum AS INTEGER NO-UNDO. DEFINE INPUT PARAMETER phDataSet AS HANDLE NO-UNDO. DEFINE QUERY qOrder FOR Order, Customer, SalesRep. DEFINE VARIABLE iBuff AS INTEGER NO-UNDO. DEFINE VARIABLE hBuff AS HANDLE NO-UNDO. DEFINE DATA-SOURCE srcOrder FOR QUERY qOrder Order KEYS (OrderNum), Customer KEYS (CustNum), SalesRep KEYS (SalesRep). DEFINE DATA-SOURCE srcOline FOR OrderLine. DEFINE DATA-SOURCE srcItem FOR ITEM KEYS (ItemNum). phDataSet:SET-CALLBACK-PROCEDURE ("BEFORE-FILL", "preDataSetFill", THIS-PROCEDURE). phDataSet:SET-CALLBACK-PROCEDURE ("AFTER-FILL", "postDataSetFill", THIS-PROCEDURE). phDataSet:GET-BUFFER-HANDLE("ttOrder"):SET-CALLBACK-PROCEDURE ("BEFORE-FILL", "preOrderFill", THIS-PROCEDURE). phDataSet:GET-BUFFER-HANDLE("ttOline"):SET-CALLBACK-PROCEDURE ("AFTER-FILL", "postOlineFill", THIS-PROCEDURE). phDataSet:GET-BUFFER-HANDLE("ttItem"):SET-CALLBACK-PROCEDURE ("AFTER-ROW-FILL", "postItemRowFill", THIS-PROCEDURE). PROCEDURE preDataSetFill: DEFINE INPUT PARAMETER DATASET FOR dsOrder. QUERY qOrder:QUERY-PREPARE("FOR EACH Order WHERE Order.OrderNum = " + STRING(piOrderNum) + ", FIRST Customer OF Order, FIRST SalesRep OF Order"). END PROCEDURE. /* preDataSetFill */ PROCEDURE postDataSetFill: DEFINE INPUT PARAMETER DATASET FOR dsOrder. DO iBuff = 1 TO DATASET dsOrder:NUM-BUFFERS: DATASET dsOrder:GET-BUFFER-HANDLE(iBuff)
ETACH-DATA-SOURCE(). END. END PROCEDURE. /* postDataSetFill */ PROCEDURE postOlineFill: DEFINE INPUT PARAMETER DATASET FOR dsOrder. DEFINE VARIABLE dTotal AS DECIMAL NO-UNDO. FOR EACH ttOline WHERE ttOline.OrderNum = ttOrder.OrderNum: dTotal = dTotal + ttOline.ExtendedPrice. END. ttOrder.TotalOrder = dTotal. END PROCEDURE. /* postOnlineFill */ PROCEDURE postItemRowFill: DEFINE INPUT PARAMETER DATASET FOR dsOrder. DEFINE VARIABLE iType AS INTEGER NO-UNDO. DEFINE VARIABLE cItemTypes AS CHARACTER NO-UNDO INIT "BASEBALL,CROQUET,FISHING,FOOTBALL,GOLF,SKI,SWIM,TENNIS". DEFINE VARIABLE iTypeNum AS INTEGER NO-UNDO. DEFINE VARIABLE cType AS CHARACTER NO-UNDO. DO iType = 1 TO NUM-ENTRIES(cItemTypes): cType = ENTRY(iType, cItemTypes). IF INDEX(ttItem.ItemName, cType) NE 0 THEN ttItem.ItemName = REPLACE(ttItem.ItemName, cType, cType). END. END PROCEDURE. PROCEDURE preOrderFill: DEFINE INPUT PARAMETER DATASET FOR dsOrder. BUFFER ttOrder:ATTACH-DATA-SOURCE(DATA-SOURCE srcOrder:HANDLE, "Customer.Name,CustName"). END PROCEDURE When I execute the code, I have this message : FILL requires an attached data-source for buffer , or an active before-fill callback procedure. (11874) - See more at: community.progress.com/.../1904 When I execute the code, I have this message : FILL requires an attached data-source for buffer , or an active before-fill callback procedure. (11874) - See more at: community.progress.com/.../1904
