Please help! Problem with jdbc updateDate
pease
I am trying to update a Progress DB via JDBC driver. Can read records
and update string fields with no problem but cannot get date fields to
update properly. The sqlexception code is:
"java.sql.SQLException: [JDBC Progress Driver]:Invalid datetime format.
Error in parameter 1.This operation may have failed due to column aliasing on the select statement."
Here is the code:
import java.sql.*;
import java.net.*;
import java.net.URL;
import java.io.*;
import com.progress.sql.jdbc.*;
public class testdob
public static void main(String[] args)
try
String jdbcUrl = "jdbc:JdbcProgress:T:localhost:nemhr:nemhr";
Class.forName("com.progress.sql.jdbc.JdbcProgressDriver");
Connection con = DriverManager.getConnection (jdbcUrl, "uname",
"mypswd");
PreparedStatement ps = con.prepareStatement(
"SELECT * FROM pub.empmstr WHERE \"ss#\" = ?",
ResultSet.TYPE_SCROLL_SENSITIVE,
ResultSet.CONCUR_UPDATABLE);
ps.setString(1, "049468945");
ResultSet empData = ps.executeQuery();
ResultSetMetaData metadata = empData.getMetaData(); // Retrieve Column names
int columns = metadata.getColumnCount();
String[] columnNames = new String[columns];
for (int i=0;i<columns;i++)
columnNames = metadata.getColumnLabel(i+1);
empData.next(); // Position to record
for(int i = 0; i<columns; i++) // Print the record
System.out.println(columnNames + ": " + empData.getString(i+1));
empData.updateDate(5, // Change the date field
java.sql.Date.valueOf("1950-05-18"));
empData.updateRow(); // Update Resultset
catch(ClassNotFoundException cnfe)
System.err.println(cnfe);
catch(SQLException sqle)
System.err.println(sqle);
The exception occurs when the updateRow method executes. TIA for all
help from this august conclave of experts! ;-)
Regards,
Jonathan Pease-Strategic Planning Officer
Norbert E. Mitchell Co., Inc.
The single source for all your energy needs--
Any time, Every time.
