Answered OT - an awk problem.
ron
I hope there is a Unix guru out there who can help me.
I've written a number of awk scripts before OK, but I'm stuck on a simple but aggravating issue.
I've cut the code down to just a small test snippet:
#!/bin/ksh93
cat /tmp/testfile | awk 'BEGIN { count = 0; }
  /\(3777\)/ { print substr( $0, 66, 20); count++ };
  count > 7 { exit };
The testfile is a copy of an OE10 db.lg file (not that that's important). The above code works - and produces 8 lines of output, as it should. However, if I change the syntax of the last statement to make it an if statement - I get a syntax error:
#!/bin/ksh93
  if ( count > 7 ) { exit };
/tmp > t
syntax error The source line is 5.
The error context is
                  >>>  if <<<  ( count > 7 ) { exit };
awk: Quitting
Can someone explain what I'm doing wrong? I've used if statements before without a problem - but now ... I'm stuck.
Ron.
ron
#!/bin/ksh93
  count > 7 { exit };
#!/bin/ksh93
/tmp > t
awk: Quitting
Ron.
ron
I have solved the problem. Apparently an if statement is "invalid" unless it is inside a block. I enclosed everything inside {} braces - and now awk is happy. Strange limitation.
Ron.
ron
I may not know the particular meaning you have in mind, Tom! But if it is oriented towards something like "awkward" ... then I sure wouldn't mount an argument against it! :p
Nevertheless - there are a few things it is useful for.
