I'm using ancient, obsolete, unsupported Progress 9.1d and I should upgrade.
I'm trying to read data from a winsock control and from the DataArrival event. Each time DataArrival fires I try to get the data with GetData. I get the following error message...
"Unexpected error occurred while processing method/statement GetData."
My DataArrival code:
Any tips?
DEFINE INPUT PARAMETER p-bytesTotal AS INTEGER NO-UNDO.
DEF VAR tcpBuffer AS MEMPTR NO-UNDO.
SET-SIZE(tcpBuffer)=p-bytesTotal.
chTCP_Scanner_Steelroom:winsock:GetData(INPUT-OUTPUT tcpBuffer,"", p-bytesTotal).
Any tips?
