Multi-Dimensional Array in Progress
rcgomez11
Good Day ProgressTalkers, is there a way that i can implement a multi-dimensional array in my progress script?Thanks in advance...
Nope - the ABL is not designed to use 2-dimensional arrays like in Java. Have a look at Temp-Tables - most likely you will be able to solve your requirement with them.
Heavy Regards, RealHeavyDude.
nothing is impossible :-)
define i as integer.
define i2 as integer.
define variable arr as character extent 15.  /*3 x 5*/
&scoped-define arrIndex  ((i - 1) * 5 + i2)
do i = 1 to 3:
  do i2 = 1 to 5:
    display arr[arrIndex].
  end.
end.
&undefine arrIndex
