I IanC74 Member Jul 20, 2015 #1 Hello, Ive recently installed OE10 and for some reason some of the dialogue boxes are "blacked out" and its causing a bit of annoyance. Is something wrong with the install? Hopefully someone can help - its been a while since i did an install. Thanks in advance. Ian
I IanC74 Member Jul 20, 2015 #2 Screen shot here. Attachments 2015-07-20 16_06_23-Program Manager.png 369.3 KB · Views: 5
TheMadDBA Active Member Jul 20, 2015 #3 You need to determine if you are using an INI file or the registry to look at the color number assignments. What happens when you click on the color editor from the app builder?
TheMadDBA Active Member Jul 20, 2015 #5 The screen is or the color numbers are all set to black? If the color numbers are set to black... fix that and save the results.
TheMadDBA Active Member Jul 20, 2015 #7 Then you just need to fix them and save them. You can do that from the AppBuilder. Or you can find the INI file or registry entries you are using and correct them there.
I IanC74 Member Jul 21, 2015 #8 Thank you so much thats fixed it - i didnt realise it was that simple!
