I am submitting a HTTP SOAP request to a host and when the response is sent back I am running into two problems
1. The progress program looks to stop getting/reading the response which is chunked and I end up with a partial XML file.
2. The socket stays connected even after the program has stopped getting any response back and so the program gets caught in a repetitive loop waiting for the socket disconnect to take place
The code looks as follows
DEFINE INPUT PARAMETER pmop-file AS MEMPTR NO-UNDO.
DEFINE INPUT PARAMETER pcsavedirectory AS CHARACTER NO-UNDO.
DEFINE INPUT PARAMETER pcfilename_RP AS CHARACTER NO-UNDO.
DEFINE INPUT PARAMETER pcfilename_DT AS CHARACTER NO-UNDO.
DEFINE INPUT PARAMETER pcfilename_ER AS CHARACTER NO-UNDO.
DEFINE VARIABLE vcposturl AS CHARACTER NO-UNDO.
DEFINE VARIABLE vcfilepath_RP AS CHARACTER NO-UNDO.
DEFINE VARIABLE vcfilepath_ER AS CHARACTER NO-UNDO.
DEFINE VARIABLE vlDataReceived AS LOGICAL NO-UNDO.
DEFINE VARIABLE vcFinalResp AS LONGCHAR NO-UNDO.
DEFINE VARIABLE vcHost AS CHARACTER NO-UNDO.
DEFINE VARIABLE vcPort AS CHARACTER NO-UNDO.
DEFINE VARIABLE vcsoapaction AS CHARACTER NO-UNDO.
DEFINE VARIABLE vhSocket AS HANDLE NO-UNDO.
ASSIGN
vcHost = "api.somehost.com"
vcPort = "80"
vcsoapaction = ""
vcposturl = "[URL]http://api.somehost.com/ws/v3[/URL]" /
vcfilepath_RP = TRIM(pcfilename_RP)
vcfilepath_ER = TRIM(pcfilename_ER)
vcFinalResp = "".
CREATE SOCKET vhSocket.
vhSocket:SET-READ-RESPONSE-PROCEDURE('getResponse').
vhSocket:CONNECT('-H ' + vcHost + ' -S ' + vcPort) NO-ERROR.
IF vhSocket:CONNECTED() = FALSE THEN
DO:
MESSAGE "Host Connection failure" VIEW-AS ALERT-BOX.
RETURN.
END.
ELSE
MESSAGE "Host Connection successful" VIEW-AS ALERT-BOX.
RUN PostRequest (INPUT vcposturl).
REPEAT:
IF vhSocket:CONNECTED() = TRUE THEN
WAIT-FOR READ-RESPONSE OF vhSocket PAUSE 1.
ELSE
LEAVE.
END.
/* Save response data to .dat file */
COPY-LOB FROM OBJECT vcFinalResp TO FILE pcfilename_DT.
vhSocket:DISCONNECT() NO-ERROR.
DELETE OBJECT vhSocket.
/* Save response data to .xml file */
RUN postProcessDataFile.
RETURN.
PROCEDURE getResponse:
DEFINE VARIABLE vcWebResp AS LONGCHAR NO-UNDO.
DEFINE VARIABLE viBytesAvail AS INTEGER NO-UNDO.
DEFINE VARIABLE mResponse AS MEMPTR NO-UNDO.
ASSIGN viBytesAvail = vhSocket:GET-BYTES-AVAILABLE().
/* if no bytes to read, exit from procedure */
IF viBytesAvail = 0 THEN RETURN.
SET-SIZE(mResponse) = 0.
SET-SIZE(mResponse) = viBytesAvail.
vhSocket:READ(mResponse,1,viBytesAvail,READ-EXACT-NUM).
COPY-LOB FROM OBJECT mResponse TO vcWebResp.
ASSIGN vcFinalResp = vcFinalResp + vcWebResp.
END PROCEDURE.
PROCEDURE PostRequest:
DEFINE INPUT PARAMETER postUrl AS CHAR.
DEFINE VARIABLE vcRequest AS CHARACTER.
vcRequest =
'POST ' + postUrl + ' HTTP/1.1~r~n' +
'Content-Type: text/xml;charset=UTF-8~r~n' +
'SOAPAction: ' + trim(vcsoapaction) + '~r~n' +
'Content-Length: ' + STRING(LENGTH(STRING(pmop-file))) + '~r~n' +
'Host: ' + trim(vcHost) + '~r~n' +
'Connection: keep-alive~r~n' +
'User-Agent: Apache-HttpClient/4.1.1 (java 1.5)~r~n' +
'~r~n' +
STRING(pmop-file) + '~r~n'.
SET-SIZE(pmop-file) = 0.
SET-SIZE(pmop-file) = LENGTH(vcRequest) + 1.
SET-BYTE-ORDER(pmop-file) = BIG-ENDIAN.
PUT-STRING(pmop-file,1) = vcRequest .
vhSocket:WRITE(pmop-file, 1, GET-SIZE(pmop-file)).
END PROCEDURE.
PROCEDURE postProcessDataFile:
/* Memory Pointers */
DEFINE VARIABLE mSourceData AS MEMPTR NO-UNDO.
DEFINE VARIABLE mSourceData2 AS MEMPTR NO-UNDO.
DEFINE VARIABLE mSourceData3 AS MEMPTR NO-UNDO.
/* Processing Variables */
DEFINE VARIABLE inBlobLength AS INTEGER NO-UNDO.
DEFINE VARIABLE inPos AS INTEGER NO-UNDO.
/* -- REMOVE HTTP HEADERS -- */
SET-SIZE(mSourceData) = 0.
COPY-LOB FROM FILE pcfilename_DT TO OBJECT mSourceData.
inBlobLength = GET-SIZE(mSourceData).
HTTP-HEADER-BLOCK:
DO inPos = 1 TO inBlobLength:
IF GET-STRING(mSourceData, inPos, 4) = "~r~n~r~n" THEN
LEAVE HTTP-HEADER-BLOCK.
END.
/* --REMOVE HTML FOOTER -- */
SET-SIZE(mSourceData2) = 0.
COPY-LOB FROM OBJECT mSourceData STARTING AT (inPos + 4) TO OBJECT mSourceData2.
inBlobLength = GET-SIZE(mSourceData2).
/* -- SAVE XML FILE -- */
SET-SIZE(mSourceData3) = 0.
COPY-LOB FROM OBJECT mSourceData2 STARTING AT 1 FOR inBlobLength TO OBJECT mSourceData3.
DEFINE VARIABLE hDoc AS HANDLE NO-UNDO.
CREATE X-DOCUMENT hDoc.
hDoc:LOAD("MEMPTR", mSourceData3, FALSE).
hDoc:SAVE("FILE", pcfilename_RP).
DELETE OBJECT hDoc.
RETURN.
END PROCEDURE.
