Help with string
YZARATE
Hi i have a problem with some description in a DB progress some strings input with blank space between description, because when i send a report the description skip 1 row for this problem.
i want correct this problem but i dont have any idea.
i hope some 1 give a solution or tell how make this changes
Thanks all.
DEF VAR mystring AS CHARACTER NO-UNDO.
mystring = "abc def".
mystring = REPLACE(mystring," ","").
DISPLAY mystring.
This will remove the space in between the words.
The output will be "abcdef".
