Hi friends at Epson:
I have an EPSON TM-T88IIP and this prints quite good the fonts letter and all this stuff. But I have a problem with it : For example I create a document using Notepad, when I print it it goes slow, but when I switch to MS-DOS it goes too fast !! On the other hand, if I am using the generic driver text for it, this print pretty well. The problem is that using the driver text the printer is not able to print barcodes.
We need to make the needed fixes in order to have this printer working properly and fast under Windows. My OS version is Windows 98.
The burning question here is:
If I am using the right driver and this is not working properly, what font and driver should I need to select and what ESC characters should I need to use to fix this problem ?
This is extremely urgent !! Appreciate your help very much
Thanks,
Javier
Thanks,
Javier
