I stop the MFG/PRO service and reboot computer server.
the ./start.Demonstration is ok and it can work.
But run ./start.Production to start then show fllow message,and ./client.Production cannot open,it said no service active.
Please help me found that reason,thanks.
13:59:10 BROKER : Removed shared memory with segment_id: 425984
13:59:10 BROKER 0: Multi-user session begin. (333)
13:59:10 BROKER 0: Begin Physical Redo Phase at 696192 . (5326)
14:01:55 BROKER 0: SYSTEM ERROR: Memory violation. (49)
14:01:55 BROKER 0: SYSTEM ERROR: The broker is exiting unexpectedly, beginning Abnormal Shutdown. (5292)
14:01:55 BROKER 0: drexit: Initiating Abnormal Shutdown
14:01:55 BROKER 0: ** Save file named core for analysis by Progress Software Corporation. (439)
14:01:55 BROKER : ** The server terminated due to signal 3. (801)
14:01:55 BROKER 0: Multi-user session begin. (333)
14:01:55 BROKER 0: Begin Physical Redo Phase at 128 . (5326)
14:01:55 BROKER 0: Physical Redo Phase Completed at blk 241 off 4233 upd 7710.(7161)
14:01:55 BROKER 0: Started for hlpprod using TCP, pid 7327. (5644)
14:01:55 BROKER 0: Begin Physical Redo Phase at 192 . (5326)
14:01:55 BROKER 0: Physical Redo Phase Completed at blk 47 off 349 upd 1260. (7161)
14:01:55 BROKER 0: Started for admprod using TCP, pid 7329. (5644)
OpenEdge Release 10.0B05 as of Sat Apr 15 00:44:33 EDT 2006
14:01:55 SERVER : semGetId: Second call to dbMSG008
14:01:55 SERVER : There is no server for database /app/mfgpro/eb21/db/mfgprod
the ./start.Production source:
DLC=/app/progress/10b;export DLC
PATH=$PATH:$DLC;export PATH
PROMSGS=$DLC/promsgs;export PROMSGS
PROTERMCAP=$DLC/protermcap;export PROTERMCAP
#loop-db-start
$DLC/bin/_mprosrv /app/mfgpro/eb21/db/mfgprod -n 60 -Ma 25 -Mpb 5 -Mn 65 -L 8000 -c 350 -B 1000 -S mfgprod -N TCP
$DLC/bin/_mprosrv /app/mfgpro/eb21/db/hlpprod -n 60 -L 8000 -c 350 -B 1000 -S hlpprod -N TCP
$DLC/bin/_mprosrv /app/mfgpro/eb21/db/admprod -n 60 -L 8000 -c 350 -B 1000 -S admprod -N TCP
$DLC/bin/proserve /app/mfgpro/eb21/db/mfgprod -m3 -Ma 25 -Mpb 5 -Mn 65 -L 30000 -c 350 -B 20000 -S mfgprod -N TCP -ServerType 4GL
#$DLC/bin/_mprosrv /app/mfgpro/eb21/db/mfgprod -n 60 -Ma 25 -Mpb 5 -Mn 65 -L 8000 -c 350 -B 10000 -S mfgprodsql -N TCP -ServerType SQL
#loop-db-end
#loop-db-start
#loop-db-end
