Fun HP printer hack using HP-PJL control codes
JamesBowen
Yesterday I was off from work and I saw a fun little hack program which changes the default "READY" message on the LCD screen of an HP printer. So I created 4GL/ABL program using sockets to send the necessary PJL control codes.
Once the code was written I VPN to my work's network and played a little trick on my colleges by randomly changing the printers default message 'READY' to a random message (see code).
Have fun.
HPPrinterFun.p
/* Sample 4GL Socket Programming Code for Client Side*/
DEFINE VARIABLE clientSocketHandle  AS HANDLE NO-UNDO.
DEFINE VARIABLE sockectData         AS MEMPTR NO-UNDO.
/** Change the settings here..**/
&SCOPED-DEFINE xPrinterHost 192.168.1.17
&SCOPED-DEFINE xPrinterPost 9100
/* Create socket and connect to HP Printer */
CREATE SOCKET clientSocketHandle.
clientSocketHandle:CONNECT('-H {&xPrinterHost} -S {&xPrinterPost}':U) NO-ERROR.
IF clientSocketHandle:CONNECTED() = FALSE THEN
DO:
    MESSAGE 'Unable to Connect'.
    RETURN.
END.
clientSocketHandle:SET-READ-RESPONSE-PROCEDURE('readSocketData':U).
RUN sendRandomMessage.
REPEAT ON STOP UNDO, LEAVE ON QUIT UNDO, LEAVE:
    IF clientSocketHandle:connected() THEN
        WAIT-FOR READ-RESPONSE OF clientSocketHandle PAUSE 5.
    ELSE
        LEAVE.
END.
/* At this point, you have exited the repeat block above, */
/* so you disconnect the socket, clean up the socket */
/* handle, release any memory allocations and then exit */
/* the program */
clientSocketHandle:DISCONNECT() NO-ERROR.
DELETE OBJECT clientSocketHandle.
SET-SIZE(sockectData) = 0.
RETURN.
PROCEDURE readSocketData:
    DEFINE VARIABLE cTime           AS CHARACTER NO-UNDO.
    DEFINE VARIABLE iMessageSize    AS INTEGER   NO-UNDO.
    IF SELF:CONNECTED() EQ FALSE THEN
        RETURN.
    iMessageSize = SELF:GET-BYTES-AVAILABLE( ).
    SET-SIZE(sockectData) = iMessageSize.
    SELF:READ(sockectData,1,iMessageSize,2) NO-ERROR.
    MESSAGE get-string(sockectData,1).
    RETURN.
END PROCEDURE.
PROCEDURE writeSocketData:
    DEFINE INPUT PARAMETER socketASCIIData  AS CHARACTER NO-UNDO.
    DEFINE VARIABLE dataLength              AS INTEGER   NO-UNDO.
    dataLength = Length(socketASCIIData,'RAW').
    SET-SIZE(sockectData)       = dataLength.
    SET-BYTE-ORDER(sockectData) = BIG-ENDIAN.
    MESSAGE socketASCIIData.
    PUT-STRING(sockectData,1, dataLength) = socketASCIIData.
    clientSocketHandle:WRITE(sockectData,1,dataLength) NO-ERROR.
    RETURN.
END PROCEDURE.
FUNCTION RandomMessage RETURNS CHARACTER():
    DEFINE VARIABLE randomMessages AS CHARACTER   NO-UNDO.
    DEFINE VARIABLE randomEntry    AS INTEGER     NO-UNDO.
    randomMessages = 'READY,BUZZ OFF,TOUCH ME,STEP AWAY,SET TO STUN,ANSWER 42,GUS DRINKS BEER,FEED ME,GO AWAY,NEED MORE SPACE,POUR ME A DRINK,IN DISTRESS,OPENEDGE ROCKS,NICE SHIRT,GO AWAY,NO PRINT FOR YOU,RADIATION LEAK,HANDS UP,PRESS MY BUTTON,TAKE ME HOME,LOOKS LIKE RAIN,HELLO WORLD,NICE HAIR,NEED A MINT?,BE GENTLE,BE KIND,INSERT DISK,BUY ME LUNCH,DONT STOP,COME CLOSER,TAKE A BREAK,INSERT $2,BLACK SABBATH,GETTING HOT':U.
    IF MONTH(TODAY) EQ 12 THEN
        randomMessages = randomMessages + ',MERRY XMAS':U.
    IF MONTH(TODAY) EQ 1 AND DAY(TODAY) GE 1 AND DAY(TODAY) LE 5 THEN
        randomMessages = randomMessages + ',HAPPY NEW YEAR':U.
    randomEntry = RANDOM(1, Num-entries(randomMessages)).
    RETURN Entry(randomEntry, randomMessages).
END FUNCTION.
PROCEDURE sendRandomMessage:
    DEFINE VARIABLE chData AS CHARACTER   NO-UNDO.
    Run writeSocketData(INPUT '~033%-12345X@PJL JOB~r~n':U).
    Run writeSocketData(INPUT SUBSTITUTE('@PJL RDYMSG DISPLAY="&1"~r~n':U, RandomMessage()) ).
    Run writeSocketData(INPUT '@PJL EOJ~r~n':U).
    Run writeSocketData(INPUT '~033%-12345X~r~n':U).
    RETURN.
END PROCEDURE.
